Karma wrote:
When turning the ignition for the port engine, it makes a single "click" sound, after 10-20 turns of the key the engine fires up with no issues, I am thinking it might be a starter problem or ignition switch problem, has anyone else had the same issue and if so what was the diagnosis. Starboard starts just fine first time everytime.
(iow, assuming that you can catch this when it's acting up)
A. Put a test light on the starter motor solenoid circuit right at the starter motor (the "S" terminal).
B. Have someone turn the key to "Start" mode, and hold that position.
C. You should see a continuous light if the key switch and neutral safety circuits are good.
If not, do the same, but this time hold and wiggle the shifter (which operates the neutral switch).
If you still see a continuous light, that may suggest that the start circuit is OK.
If this circuit is OK, it should lead you to a bad starter motor solenoid, or poor armature brush contact.
Also, don't over-rule cable connections. Give these a look at also.
