I wasn't sure if I should post this in technical or motor yacht section....
Anyway, I have twin 351's in my 3288. They have somewhere between 600 and 1000 hours on them. The previous owner hardly used the boat and did not have hour meters so since 2005 I have put just over 600 hours on the engines.
We run mostly between 1800 and 2200 rpm probably 95% of the time.
The engines are in good condition with good compression and do not burn or leak oil and start quickly.
I'm just curious as to how many hours others have put on these engines before requiring major work like heads or rebuilds, especially those that operate like I do, mostly as a trawler?
