Factory transmission-gctid778769
    What is the factory installed transmission ratio on a 1988 3218 with 150 Hino"s?
    1.58 to 1
      1988 was a transition year where some were built with the 135 & paired with the 360 tranny. Others had the 150 with the 630 tranny. Engine is identical (fuel pump different setting) so people quite often call the 135 a 150. If you don't know for sure which tranny you have the ID plate is under the tranny fluid cooler.
      If you have the 360 then the ratio is 2.95/1.
      Terry
      Br$keAweigh
      1987 3270
      H/P - Powell River, B.C.
        Interesting. OK, if I buy the boat I'll check it out.
