Hi,
The fresh water pump seems to not be working on this boat. There is power to the switch so I'm assuming the DC breaker is OK. The pump is buried deep down the staircase and is hidden by the cabin heater above it. On this model Bayliner, only the top stair tread is removable along with the middle riser. Older models had the bottom stair tread removable.
Question is, how do I get to the pump without disassembling the staircase?
thanks
thanks
