So the story goes like this,
I have a 1996 Bayliner 2855 with a 7.4L Carbureted engine, Bravo III outdrive. The boat had never been in salt water before I bought it and I decided to install a closed cooling system on it before I started using it in Salt water. That was last spring and it worked great the whole summer, until the last run of the year. It started running hot after being out for about an hour. I shut her down and let it cool for a while and then pulled over to a nearby wharf. After retrieving my trailer I moved her from the wharf to the trailer. A load squealing sound was heard for about 15 sec and then stopped.
After getting her back home I tried to run her again(muffs with hose on) and experienced similar results. She would fire up fine and run for a couple of minutes and then get hot.
Thinking it might be something to do with the closed cooling system I removed the whole system and returned to the way it was. Fired it up and the same results were experienced. Ran fine for a couple of minutes and then got hot.
Could it be the water pump on the engine?
Steve
Steve
