PLEASE HELP SUPPORT OUR SITE
Thanks!!!!
Cobra - Upper Gear Case Fill - Repairable?-gctid392783
I was draining the fluid in my gearcase. To get air flow I intended on removing the upper fill screw. To loosen I tapped a screwdriver lightly with a hammer and the dang thing popped inside. :-( Does anyone know if this is a helicoil. It appeared to be so. Also is it replaceable?
After further examination, what broke was not a gear oil fill but rather a screw that I've read is the screw never to touch. :-( It actually has water behind it not oil. I plugged the hole with a fat washer and a bolt loaded up with 5200. I would like a better solution though as although its functional looks terrible.
Gennerally, the nut that fell into the water cavity can rattle around in there. But, it is posslible that it could get caught in the water outlet and obstruct the water flow. Best to fix it back to original by retrieving the nut and putting it back together with the correct seal.
Remove the outdrive and get the nut out and add a nut to the back side of the bolt was how mine was repaired by a guy who does OMC's all the time. So you have the right idea but still might want to consider to pull the outdrive to get the nut out and one on the back of the bolt. While at it replace the bellows at the same time is not a bad ideal.
Oh yeah we removed the bolt from inside. The out drive was off when it happened. Stupid fill screw. I should have known better. It was on the opposite side as the other two. :-)
On the bright side, my outdrive is shifting better than ever. I recommend the wiper and oring replacement on the shift rod if shifting takes a lot of effort.
