I have a 2008 Bayliner 185 4.3L that has no power going to the ignition switch. I have replaced every fuse in the boat, including the ones in the engine compartment. I have checked every wire and do not see any breaks in the line. Even the 90 amp fuse on the starter is fine. Is there a fuse I am missing?? I replaced a 15 amp fuse at the back of the engine, a 20 amp fuse at the front, I checked the circuit breaker and it seems fine, and I replaced the 90 amp fuse on the starter. I also replaced every fuse in the box up front. Is there a fuse somewhere else in the line that I am missing?? I checked the voltage at the ignition switch and no voltage is making it to the switch. Every other thing on the boat works, just not the ignition. Please any help would be appreciated.
Bayliner 185 4.3L-gctid392540
