Have just purchased a 1990 Ciera 2775 and would like to use an onboard gen for A/C. Not sure how to ground it. Any thoughts? Thanks.
Generator Ground Question-gctid392411
When you connect the Air Conditioner to the boat's AC circuit (using the standard three prong male plug and female receptacle), the ground will take care of itself.
Volvo Penta Duo Prop Drives
If you leave a "post", rather than a "comment", our members will see recent thread activity! -
Are you refering to a portable generator?
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
Where am I right now? https://maps.findmespot.com/s/218P#history/assetsComment
I questioned that also, Kevin, but he did use the term "onboard", so I went with O/B.
If you leave a "post", rather than a "comment", our members will see recent thread activity!Comment
Sorry guys...I DID mean a portable generator...thanks for replying...sorry for confusion and wasting your time...
No waste of time at all.
If you carry all three conductors (hot/neutral/ground) from the Generator to your S/P inlet fitting, and make sure that the polarity is correct....., you will be OK.
Again, Thanks for the help...I will be using a locking plug or definitely a three-prong...4000/3200 portable generator...
baylinerpro1 wrote:
Again, Thanks for the help...I will be using a locking plug or definitely a three-prong...4000/3200 portable generator ...
Buy ther cheapest, most unreliable POS generator you can find.
That way we'll have plenty of things to discuss here on the forum, regarding your trials and tribulations. :livid:
Well, we're half teasing you.
The larger 4kw Non-Marine generators are very big and bulky. Not an easy generator to carry on board, let alone put on a swim platform. Plus they are no where near as quiet as the EU series.
This is discussed often here, and usually the Honda EU series comes out on top for size, power and low DB's.
Will a 2kw or 3kw do the trick for you?
Thanks for the great suggestion but I had already purchased a 3200/4000. It is a bit heavy at 103 lbs. but I wanted to run both the fridge and a/c if we go on a week's trip up the intercoastal...with several stops of course. Thanks again for the advice...if this one is too cumbersome I can use it on the farm..and will go for the HONDA
