replace fuel tank-gctid392399
    has anyone replaced a fuel tank on a 1995 2452 cruiser,if so,where do you find a matching tank,what is the cost,or is there an alternative to having to pull the tank,also is the tank mounted with brackets that you cant see
    Where are you from? I had mine replaced, same boat, Had one made at Ballard sheet metal in Seattle, went to a .125 thick not the cheesy .080 Bayliner puts in them, There is a place in bellingham that has direct replacements, although when I called they were going to have to make it, so i opted to have a thicker one made they also put the baffles in the tank, I paid 1000.00 probably paid to much but that is what I wanted, Doug
      hey doug, did you replace the tank yourself and did you remove the engine to do it or cut a hole in the floor.if you had it done by someone else,what where the labor costs. steve from crestview,fl.
