1989 OMC 5.7 engine is out cant get off the shift cable hose from the inner transom,,whats the trick, i cant get a wrench on it becasue it recessed, and get a socket on it becasue of the shift cable...I removed the y pipe still no luck...which tool..do I use to get acess to the nut..do i have to remove the inner transom housing also?
HELP!!! How do I remove the shift cable hose-gctid392372
If you are replacing the hose and shift cable, can't you cut them and get at the nut with a socket?
Greg
The shift cable is brand new...to remove it I have to take off the gimbal housing, which I guess I could do then maybe I could get a socket on it but to tell you the truth I dont think a socket will do because the nut is recessed and there is no clearance to even get a socket on...I will try to send a picture of the situation, I am way frustrated.
Attached files [img]/media/kunena/attachments/vb/696031=28873-034.jpg[/img]
