Rebuilt / New Engine recommendations please-gctid392262
    Morning fellow boaters,
    My mechanic called me again this morning, informing me of what seems to be a lack of metal between cylinder 2&3 cause the gasket to non exist causing in my block needing work.
    now, from what i can recall, the cylinder walls cannot be fixed?
    Anyone know where i can get a reman block or new engine?
    1997 Mercruiser 5.7L / 350
    Do a search, you'll find many places, people, and opinions.
    Does your mechanic not have a recommendation? He must have "a guy"?
    Geoff & Jen
    Shocking Lesson
    1986 3870
    Hino 175's
      MichiganMotors.
      http://www.michiganmotorz.com/
        Hmmmm- am I to understand that this is a siamesed block? What exactly happened that there is a "lack of metal" between the cylinders?
        If it's only a blown head gasket (where missing metal between the cylinders on the gasket makes more sense) it should be fairly simple fix. Before drop lots of cask on a reman or crate engine, I'd get the rest of the story first.....
        to answer your question, you can source an engine from Mercruiser directly, Michigan Motors, and other vendors.
          Im heading to the cottage tomorrow and will be seeing the damage for myself as well as talking to the mechanic in person.
          I wish it was just the head gasket and not a complete engine overhaul.
          Thanks for the responses, everyones insight counts!!
          from what i got, he said there was absolutely no gasket between cyl 2&3, thus resulting in the 30lbs of compression i assume. Its weird, because the engine would start, run, but would slow down once over 25mph.
          All other cylinders had excellent compression
            The siamesed cylinder block was the SBC 400 (6.55L). These don't fair well in the Marine world.
            I wish that they did, because this would be a good option for many of us.
              Believe I found a major part of the problem.....the OP's signature has him going "62 mph...so far"...
              Overstressed engine = dead engine....
                pau -- that was a one time open up when i bought the boat.
                i wakeboard behind the boat..i dont wakeboard at 62mph.
                majority of the time, my wife is driving.
                  62mph...????? that's a bit high for me. I prefer to W/B at around 55-58 mph!
                    lol.
                    anyone know of a reputable boat engine sales place?
                    Im in Canada, i cant seem to find too many around here
