32xx turbo help-gctid391902
    Hi all. Did a search on the site and was not able to find any threads on removing the turbo for rebuild.
    Does any one have a link to a tutorial on how to remove the turbo?
    I have no idea what you're working on, I'll presume some sort of diesel.
    In general, turbos have an oil feed, an oil drain, exhaust turbine flange mounting bolts, and intake plumbing and that's it. Really simple.
    What is your issue exactly?
    Chay
      Post this over in the MotorYacht section. There's a number of people over there that know exactly what you need to do.
      Pat
      Paragon
      1999 4788
