Yes, I searched first. Flame throwers on safety please. I have the 1987 GM 305's and have always been confused by the call for 30w straight weight oil. I assume having a 10w-30 or 15w-40 would protect better when starting cold, point being a lighter weight oil gets pumped up easier and faster. I realize that with many oil related questions it often comes down to opinion; for example I do not believe there is scientific evidence that proves sythentic oil protects engines better. If anyone has good (hopefully backed by science) advice to share, it's oil change time for Personal Space. What oil is best - not brand but weight please. Also, I just picked up a "MityVac" oil extractor and I simply can't weight to use it. Man, I crack myself up.
Straight weight, straight talk-gctid391713
"Straight 30W" is just that. Oil the holds it's viscosity throughout it's operating spec.
Multiple viscosity oils have polymers added to lower weight oil (cheaper oil too) that unwind as the oil heats and make it act thicker. In a perfect world 5W-30 will act just like 30W at temps.
The problem is we seldom get to those temps reliably in boats and the work in a harsher world causing the polymers to break down.
I use straight 30W... no need for efficiencies earned with multi-vis oils on my boat.
The real need for multiviscosiy oil is when you run in really cold temps like winter.
The newer engines also run at tighter tolerances then those of old so the need for thinner oil upon start up is necessary. If its a new engine I would go 10-30 other wise 30w if you only run in summer
1989 Avanti 3450 Sunbridge
twin 454's
MV Mar-Y-Sol
Twin chevy 350's inboard
Ben- Jamin
spokane Washington
I don't think there's any question that synthetic performs better, whether you want to pay the difference for that performance is your decision.
A great place to expand your knowledge of oil is BITOG:
http://www.bobistheoilguy.com/
Click on "oil forums" at the top to the page and let the info download begin......
orca wrote:
I use 10-30 dino oil, or 5-40 rotella syn.
Actually most new cars 5-30 is recommended. I am leaving out VW's and a few others. What i recommend is what is listed for use on your engine.
I use straight 30 weight in my 85' 3.0 / 140 hp engine that is in my boat.
My 4-cylinder Volvo calls for 10w-40. I've used 20w-50 and 30w and had 80psi on startup when it was cold out.
The manual should have a range of weights to use for the temperature of your area, along with a recommended oil pressure. Adjust weights accordingly.
Fish-a-Palooza wrote:
Synthetic oil does protect an engine better and there is scientific evidence to prove it. You can't burn synthetic and so there is no possibility of varnishing. I have fixed sticky/ticking lifter problems by doing a single oil change from dino to synthetic.
Synthetic will burn- it'll take much higher temps to do so, but it will burn. One of the chief benefit of synth is that its molecular structure holds together under heat and pressure much better that dino.
I use what the mfg says to use. In my case, it's 20-40 dino. Merc started allowing full synthetic back around mid-90s I think. They also allow single weights based on the surrounding temps, not the operating temp.
Single weight oils have one advantage, they shed heat better than multi-vis. Many boats have an inline oil cooler, so heat shedding is not an issue. I haven't seen any benefits to synth oils that would make me spend the extra money for them. I've got two Dodge engines that have over 200k each, and a Ford Diesel > 300k with normal dino oil with regular changes.
In my airplane, where the engine was designed by Archimedes, they spec single weight and that's what I run. No synth, no multi-vis, only thing I change from the old oil is a detergent to scrub the insides and deposit the gunk in the after-market installed oil filter. If I didn't have a filter I would be using non-detergent.
