Well, in this week's overheat chase I went to the raw water flow test as prescribed by Mercruiser (7.5 qt @ 15 seconds)
I thought I'd found the culprit when I discovered a piece of old plastic pump housing lodged in the impeller last week, but alas, that made no difference in my high rpm overheat problem.
Anyway, checked raw pump output at 1000 rpm, hit the 7.5 qt mark consistently. ( Boat is in the slip btw).
Then I decided to check the final flow to manifold from thermo housing, hit the same flow--all good.
Out of curiosity, I then revved up to 2200 rpm to observe water flow at higher rpm---flow was great, but noticed the water was now a very dark grey! At low rpm was clear sea water. I am thinking I'm possibly getting exhaust gas in the circulating water at a high rpm??
Manifolds off again now, flow through them looks good, flappers still in place....etc!!!
My next test is for high rpm on the water investigation to check for collapsing hoses, but this dark water has me concerned!
