Hello to everyone .... looking for some help on this. Our 1984 bayliner 3270 comes equipped with the Crusader 3.8L 229CID with 4BBL Rochester 4MV carb (model # 17082403). Engine is rated at 185hp. This 4BBL carb was used on everything from Crusader back in the day from the 229CID 3.8L V6 all the way up to the 454CID V8. Different combinations of primary jets and rods, secondary rods and PP springs and air valve shafts made this carb very tuneable to match engine requirements and set up. I am faced with rebuilding or buying reman but for the life of me I cannot find any data on what the stock jetting setup would be for this carb on this particular engine. Most of the reman carbs I find on-line show some details but no specifics on standard jetting that would be included. The carb for a 454 would be set up completely different for the 229 wrt primary jetting, rods, secondary, etc.
Any help and support would be greatly appreciated.
Cheers
Cheers
