I have a 98 2355 with an Alpha 1 Gen 2 outdrive. The tilt/trim rams sat in the up position for a while and need assistance to move up or down. So I am assuming they need to be rebuilt. The price for the rebuild kit is really expensive ($160 each) and the cost for mercruiser replacement is rediculous ($403 each). Has anyone used a sterndrive engineering replacement ram? I can get replacement rams from them for less than the rebuild kit for the mercruiser ($120 each). Am I throwing money away by getting this cheaper alternative?
Also, it looks as though the trim position sender wires are completely corroded at the sender. Do I really need to have these working? They are about 75 buck each. What function do they provide me?
Thanks,
Jason
Thanks,
Jason
