I don't know that there is much to take away from my experience other than carry towing coverage, but here goes:
I had the family out on Puget Sound last Friday heading from Olympia to Brownsville. With about 3 miles remaining in our 45 mile trip and while cruising at 3400 rpms and 19 knots the engine sounded as if it had been thrown in neutral. It was the guardian system kicking in and I immediately throttled back to idle and looked at the gauges, which I always do any way. The all knowing smart-craft gauge had the temp at 190 and rising.I shut her down, dropped anchor and lifted the engine hatch and there was no visible issues with hoses,belts, fluids or leaks but damn were the risers hot. I figured my 5 month old impeller had died a violent death or I had inhaled some eel grass but i was wrong. In looking at it today, it turns out that the impeller is fine but the sea water pump shaft literally broke in half. It looks as if the shaft was simply defective and chose that time to give up the ghost. Not sure if anyone has had the pleasure of this experience, but as I said, get and keep your towing coverage. God knows it just saved me at least $2500. Do any of you replace the entire pump just based on age and hours? My Horizon 6.2 and Bravo II is from 2007 with just over 420 hours on it.
