Looking for some conclusive guidance here with the help of the great members on this forum.
I have 2004 Bayliner 288 w/350 Mag. Shore power and 2 batteries.
Need new batteries. Have MBS with the typical 1-2-both-off selector. Boat came with 2 27 sized, what appear to be Walmart batteries, Maxstart I believe is the name, not sure the age. I am concerned about fumes and corrosion from typical flooded batteries, especially since I can smell the one going bad!
I have decided to replace both, in a precautionary move to avoid being stranded. I spend some weekends on hook, and some in marinas. I DO NOT have shore power at home marina, as it is dry storage (rack). So I am charging batteries while running or visiting marina. I am considering putting in AGM's, am looking at Optima blue top 27's. I now read one of the drawbacks to them is AH (amp hour I think) rating. I like the idea of no venting, adding water and freezing issues. Not entirely sure the best choice though. Am also considering going with one starting and one deep cycle, both flooded. If I go with two battery types am I asking for trouble? If I have 2 types how would I use the MBS, I would guess on battery 1 (starting) for engine start and run, and battery (deep cycle) while on the hook. If I do that, in morning when I start back up on battery 1 can I move switch to battery 2 to charge it, or move to both to charge both. Will the stock alternator "know' the battery difference? Will it charge both types at once? Otherwise I have no recharge method until I stay overnight at marina again.
Not to sound snooty, but I do not want to choose based on price, I do not mind paying for superior performance, don't want to cheap out and be sorry. I was ready to order 2 of the Optima, which claim to be dual purpose, and be done. But now not sure.
Is there a reliable resource to give guidance on the use of the MBS and when to be on 1-2 or both settings. I have always found it confusing and whenever I arrive at the boat I put the switch on both and go, only changing to either one or two when I anchor up overnight, to assure I can start in the morning by reserving one battery.
By the way I have a "smart charger" wired to the batteries, not the switch. It will not come off bulk charge on the "smelly" battery. I leave the MBS on both when on shorepower too, not sure if that is correct either.
Appreciate any help. Thanks
