I no longer need or wanter the seacock located below the waterline in the engine bilge and would like to go ahead and remove it just to get it outta the way. Until I can appropriately repair the hole using the recommended 12-to-1 grinding protocol then filling with 'glass layers and epoxy (unless there's a better way), does the industry make a plug (bronze, stainless steel, etc.) I can install temporarily until I can effect the permanent fix. Have done extensive net research to no avail. Thnx.
Wayne
Wayne
