Powerpilot By Navico-gctid390664
    Simrad bought out Navico. Simrad may have the original instructions and or parts to fix the unit. If they deny having a manual, look at the earliest Simrad AP-12 manuals
    Guest started a topic Powerpilot By Navico-gctid390664
    This unit was on the boat when I bought it, and has worked fine until a couple of months ago. When I turn the unit on it goes into standby mode just like it is supposed to. But when you push the right or left controls the control unit blinks two times and goes back to standby. It is not engaging the ruder at all. If some of you have this unit or had it in the past and have had a problem like this and were able to over come it in some way. I would like to hear from you.
