WOW what a bummer. We recently purchased an 02 2855, and had a great 200 mile run home from Lake Union to Comox B.C. The boat preformed beautifully the entire trip. We spent two weeks cleaning and detailing, and we've had nothing but trouble ever since.
Here's the symptoms:
starts and idles fine
won't come up over about 2500 rpm
won't get up on plane
no throttle response after about 1/4 throttle
smell of un burned fuel in the exhaust
runs a little rough and shudders a bit over idle
Here's what i've tried:
changed rotor, cap, plugs, wires, coil, fuel filter. No change.
Suspected bad gas so tried fresh fuel from another source.....no change
Here's what I think... I suspect a ghost in the machine!!!!
Either the ECU ( or computer) or one of the many sensors or the wiring harness
Has anyone had similar problems, any help would be greatfully appreciated.
thanks in advance
Chris
thanks in advance
Chris
