Hypothetical Comparison - Cooling Systems-gctid390458
    On my Half closed cooling system, the manifold and risers saw salt water and the block saw E/G.
    On my now, Raw water cooled system, everything sees Salt water.
    Now, I've got a fresh water flush inlet that allows me to hook up the hose and run fresh water through the entire system. If I flush after each use, what could I expect in terms of life expectancy of engine, manifolds and risers?
    Note: my engine does not use the outdrive for intake, but rather a through hull fitting and seacock which can be closed to stop any sea water from entering the block while the hose is hooked up.
    ...discuss _^_
    Some people have your same setup and some use saltaway attached to the end of hose. i had a 14 year old 3.0 litre that i flushed after every use and replaced nothing. it just finally wore out.
      Maybe I'll try the salt away too.
        No body else?...
