OK I'm stumped. I'm trying to align the engine so I can install the outdrive. I can't get the dang tool to go in. I've run the motor mount adjustment from the top to the bottom. No matter where I have it, I can't get the alignment tool to go into the splines. It seems as though the engine is to high at the rear I thought bringing the front mounts up, would fix the prob but it's not.
Oh, if you've been following my progress, I got my engine in for about the 5th time and when priming the pump realized Michigan Motorz sent me and engine with a bad oil pump. We just replaced the pump thankfully I didn't have to pull the motor to do it.
Greg
Greg
