I have an overheating problem with my boat - Mercruiser 454 (7.4L) with a first Gen Alpha One (1987). I have had it in the water once, and the temperature shot up over 200 just as I left the dock, setting off the alarm. As I was maneuvering back to the dock, the alarm stopped, and the temperature returned to normal. I ventured out and eventually had a full boating day with no overheat issues whatsoever.
Back on the trailer, on the muffs, the engine overheated again. I checked the flow at the end of the hose coming from the outdrive inlet to the steering cooler, and it is a slow flow. At the thermostat inlet, it pulses. I checked the thermostat in hot water and it works fine, so I put it back in. I suspect a weak flow of water that exits to the exhaust manifold and does not flow through the block.
The outdrive is old and corroded. I replaced the impeller with a full rebuild kit, and put as sealant on the gasket under the pump base. The old impeller looked fine. I tested again and the problem is the same. I see no kinks in the hose feeding from the outdrive to the stern, or from the stern to the water pump cooler.
The engine was just rebuilt 9 hours ago. The P.O. had it in the water, and never had an overheat problem. When I ran it that first day in the water, it worked well after the initial overheat. I wonder if the pump is sucking air somewhere on the muffs, an area that gets flooded after it sits in the water for some time. Any ideas for troubleshooting? Is there a pump drive gear that could be bad? Any likely place air could be ruining the pump draw?
