Dinghy motor wont idle-gctid390273
    I have a 10984 johnson 8hp. I had the carb cleaned and ever since then the damn thing wont idle. Does anyone know where the idle adjust is on this thing?
    Try to follow the linkage to the carb where there should be a adjustable set screw where you can make a simple adjustment there. If you messed up something on the rebuild, that's would be a different story.
