Hi
I have a Lowrance EP60 sensor, the install is correct with a pre screw on filter, upright and the flow in the correct direction.
I checked the 2452 today after some bad weather and fired her up and the sensor is not showing a flow at idle, if i rev the engine it will show a flow reading.
Now i am concerned of the accuracy when i have been cruising and the total fuel used etc.
Any views appreciated.
