I just finished Epoxying (West Systems) my 8' piece of laminated plywood into a boat transom when I've come to realize I mixed with too little slow hardener.
The mix ratio was supposed to be 3.5 parts to 1.
I mixed 12 ouches or resin to 1.5 ounces of hardener with adhesive filler added for thickener. (about 6 batches)
The bad part is I used the regular fast cure with metering pumps on the outside edges and it has already cured. (Been about 4 hours now)
Am I doomed or will it eventually cure?
