Jensen MS160 Marine Radio partially works-gctid389832
    Hello again, new owner of a 2004 185 bow rider here. Boat has the Jensen MS160 Marine Radio factory installed and it seems to not work correctly. It turns on and off, lights up, you can change channels and stations with the seek buttons...even the little ST word pops up to show you a good station reception. I've tried the stereo and line in and have never gotten even a peep of sound. The volume up doesn't seem to work...and when i hit volume down it only displays V-00...and i also only got the mute button to work once and it just flashed MUTE at me a couple times. I'm no mechanic but I took a basic look at the back of the unit... It appeared everything was plugged in... Although it was a mess of wires. Could I just have a faulty unit here...or is it something else do you think?
    Thanks.
    Have you checked the back of the speakers to ensure the wires are connected?
      Yea the speakers are connected... I guess that doesn't necessarily mean they work though either.
      The previous owner said he didnt use the unit so he had no idea.
