My 98 2355 5.0 Chevy temp alarm chirps on and off all the time. When I disconnect the temp switch on the thermostat housing is stops.
I,ve changed the thermostat. the impeller and the switch No joy. My gage says 175 degrees but the thermostat is a 160. Is my engine running to hot? What is the set point of the switch? What should I do next?
Thank you
Thank you
