I recently reinstalled my cobra out drive back on to my 1989 Bayliner 2150 w/ a 5.8L, and she started on the second try. When I went to put it into gear the prop started moving at a low RPM yet the throttle was very stiff and would not fully engage. I didn't want to force it so I didn't push my luck and just shut her down. After checking the newly filled gear case the oil was filled with tiny bubbles, does any one have any idea what I am up against? Could I have not aligned the shift rod end correctly when reinstalling the out drive?
Please any help would be appreciated!
Matt
Akron, Ohio
Matt
Akron, Ohio
