So I just bought my Trophy 2002 not too long ago and I was just out on the water. I checked the wash down and there isnt any wires hooked up to the pull knob (thus making the wash down not turn on) the pump is down there with hose hooked up to it, just nothing hooked up to the knob. Any ideas on how to get this going?
wash down.-gctid389415
The pump may be hooked into the live well, with a diverter valve to direct the flow....otherwise, it's time to trace wiring...
Where are you located? Please add the info to your sig, so local members can give you a hand...
Im in Oly Wa. Hmmm. I took a peek in there to check for loose wiring and didnt see anything. I will take another look. Never thought about it being hooked in with a diverter. I will check that out and update here aswell. Thanks.
