Hi Guys,
I am using the 3M 4000 to caulk the rub rails and as I do I want to feather it nicely and when I am done be able to clean up. What is the best product to use? Thinner, Kerosene? I have siliconed tubs and have used water based type products that I can feather with my finger as I keep dipping it in a Dixie cup filled with water and feather the silicone. I would like to use this technique on the rub rail unless there's another way to do it?
Since water is no good to feather with (unless it is) what chemical have you guys used with the "Wet the finger and feather type technique" for the rub rail and what chemical would you use to clean up with if not the same. I ask it this way because you may use something different to feather technique it where it contacts the fiberglass.
Please let me know how you would silicone and feather the rails and what chemicals you would use?
Ed
Ed
