Trophy fuel tank replacement-gctid388958
    Replacing the fuel tank on Trophy seems like something fairly common. After this is done, is the hull integrity significantly compromised? What should I look for when buying a used Trophy that has had the tank replaced? '93 2502 Trophy is what I'm looking at. Thanks
    Not the same as yours but my limbers were half plugged with resin from the factory layup. This contributed to water under the tank. Make sure theyre clear and kept clear.
    ________________________
    John
    1988 Bayliner 2556
    5.7L OMC Cobra
