Probably a silly question, but Ima ask anyway.
Should I coat the transom, completely, under the drives, trim plates, everything, with (interlux Primercon) Primer? Obviously, the manufactuer didnt.
And after I get the metal back on, all that has a bonding wire, that is, stay 1.5~2" away with the bottom paint, correct?
