I am trying to determine why my water pump doesn't stop pumping when the cabin switch is turned on and all the faucets are closed. I'm talking about the fresh water system, not the engine cooling water pump, etc.
First off - I get steady, fast flowing water from all 4 water faucets - I have the galley sink with hot/cold, I have the head sink/shower with hot/cold, I have the transom shower with hot/cold and I have that courtesy deck sink with cold only.
My understanding of how the pump should work is this:
Fill the holding tank, turn on the pump. The pump sucks the water up from the holding tank, fills the water heater, all the lines, etc, and then once a "pressure" point is met, the pump should automatically stop. From that point on, I believe it should be an "on demand" system. Turn on the water at one of the 4 stations, the pump kicks in. Turn the water off, and once enough pressure has been built up, the pump should then stop.
Now the fact my pump never stops (it used to), I'm pretty sure I have a leak somewhere - but the problem is - I can't find any sings at all of a leak. I thought it was where the plastic quick connect from the cold supply elbow going into the water heater wasn't gripping tight. I replaced that with a SeaTech fitting, and this one grips the metal pipe tight. Everywhere that I have access to, and I have checked several times now - everywhere inside is dry.
I've read other threads where people suggest pressure testing the lines/system. That's great! How? How do I actually do this, and then, what would I look for to find WHERE the leak is? If I don't see water dripping out from the lines, how am I supposed to find the leaks when pressure testing the lines/system?
Thanks in advance for any help.
