Background - In 2005 I bought a 285 brand new with the 350 Mag Bravo 3 in it.
I boat on the Chesapeake bay and the boat has always been kept in a completely enclosed boatel year around. All of my maintenance (even oil changes and winterization) is done by my marina - an authorized gold/platinum level dealer or something like that.
I have close to 1200 hours on it (not a typo - I do alot of trolling during the spring trophy season for striped bass each year
Around 700+ hours the starboard exhaust manifold developed a leak so my marina replaced both manifolds and risers and performed a 300 hour service as well.
The problem - during the spring, I noticed a little bit of oil in the bilge and had the mechanic check it out. It was deemed "residual" since no leak could be found. I had the 300 hour service completed again a couple of weeks ago and an oil change the Wednesday before Memorial day weekend.
I left for the weekend and on my return Monday I decided to check the bilge. Much to my dismay I saw alot of oil sloshing around in the bilge. The oil pressure and engine temp was fine the whole way home. No alarms were sounded and the boat ran well.
The marina checked the engine later in the week and there was very little oil left in the engine (per the dipstick measurement) and they removed 3-4 quarts of oil from the bilge. No leaks could be found however.
They are pulling the engine this week to see if they can find the source of this big leak. I was hoping for some opinions on what might be the issue here. They have hypothesized that it could be an oil pan leak or oil pan gasket. Whatever it is, something has let loose.
Thanks in advance for comment/replies.
Best,
Jim
Best,
Jim
