2000 Mercruiser 3.0, inline 4 cyl, no thermostat; Alpha outdrive.
Engine has always operated at 125 deg (by gauge) regardless of load.
Straight to it - on last outing, temp fluctuated around 150 - 175 on the run...falling back to 125 - 140 idling along; eventually crept up to 175 by days end....and then finally and suddenly slammed over to 250, triggering the temp alarm.
I have rebuilt the pickup pump in the lower unit with new impeller, wear plate, gaskets etc. ; AND installed a new circulating pump on engine.
Ran fine in the driveway, sucking from a tub OR on ears - 125 deg.
TODAY -first "river" test since repairs, BUT - a repeat. Started out fine, crept up, eventually OVERHEATED.
Anyone wanna' speculate?? Did I do something wrong, or have I overlooked another possible cause??
(Other observable factors: there are two discharge holes; one on either lower side of the gimbal housing - but only one spews hot water...and cool hose water tricles with exhaust gas from the prop cone. If I block that hole, the other side will discharge - but seemingly less volume AND a greater amount of WARM water from the prop cone. Pertinent??)
Any advice, suggestions, clues welcome.
