Microwave and heat/air went out on me-gctid387297
    Got up this am to have breakfast and take the chill off and microwave and heat were dead while hooked up to shore power. All else working ok. Fuse panel looks ok. What's the next step to troubleshoot? Thanks.
    Are you sure the shore-side breaker hasn't tripped? Do you have 110VAC at the boat's panel?
      Yes I reset the breaker and that did the trick. Thank you.
