I am barely getting a reading on my speedometer. Sometimes i'll get something, sometimes not, but it never makes it above 20MPH, so i'm guessing there's a block somewhere since i get some reading. I checked the pitot on the outdrive and there doesn't appear to be anything there unless it's really lodged in the back. I traced the tubing from the speedometer to the point it goes through the transom at the outdrive. It looks like the tube is only kept onto the speedo and the transom fitting by zipties on each end. Has anyone removed the zipties from each end and blew air through the line? I'd think I could just re-ziptie it to each end of the tube after, but was checking if that's all there is to keeping the tube connected/stopped from leaking out before i tried it. If that doesn't do it, the clog must be somewhere between the outdrive/transom connection and the pitot on the outdrive, which would be more of a pain to figure out i'm guessing.
thanks in advance...
