In the last year, our 2008 Discovery 246 has developed a couple of chronic seawater leaks into the bilges. After a day in the water, about a quart or two will accumulate in the aft bilge and about a pint in the forward bilge. I have tightened all of the hose fitting clamps and searched for signs of leaking around thru-hulls with no noticeable problems. The seal at the steering arm through the transom is a suspect, but it doesn't seem to have much salt residue there either. Has anyone else with this model had any chronic mystery leaks? It is never enough to trigger a bilge pump but don't like having salt water in the engine area.
