Bayliner 2150 Ciera Sunbridge - AQ225D Volvo Penta w/ 280 Outdrive:
My tilt unit will only go up and every once in a while it will go down (most of the time I ride with the nose pointing up at the sun! JJ). I thought it may have been the switch but I have 2 switches and it does the same on either one. The tilt motor has 2 wires coming out of it, one red and one black, and one wire, the black one, has been melted a little from the exhaust but it's not that bad... Can someone tell me a good way to start the trouble shooting - in maybe a A, B, C order? Photos would be great too!
Am I wrong in thinking that since it comes up then the motor must be good? Seems to reason that this would be the case... Also, on the top of the trim unit there is a box that I am thinking has relays of some sort??? If I use a 12v lead, say a battery charger @ 10amps(?), and ground the black lead from the charger to the block and touch the red + lead from the charger to either of the 2 tilt unit wires, should it go either up or down (depending on the wire I touch)?
Thanks!
Thanks!
