OK help me feel good or bad about this:
My Bayliner COntessa FB is set up with a MP350 (higher HP model). Runs great but noticed a little tick up in engine temp when cruising hard.
At idle and after warm-up (engine commonly spikes at ~175 before dropping) engine temp is 150to 155 (right below 160 marker or mid point between 140 and 160). She's up and running on plane she might inch up to 160 or just under. Nearer to WOT or 85% of WOT she is closer to probably 162-165 maybe a tad higher. Never approaches 180 and the temp remains stable while running at whatever speed.
Forgot to check riser/manifolds temp by hand last time out but she was still mildly warm 1/2 hour after returning to dock..no wierd smells or anything.
Impeller replaced last year (even 3 yo impeller that was replaced was good as new). Risers/maniforlds replaced 3 years ago.
Any concerns here? I just dont recall that change in engine temp (except when belts were loose ..which they are not right now).
