In a few days, I need to decide what type of oil I should purchase for breaking in my new Perkins 4.108. I read numerous technical documents and forum posts indicating synthetic oil is a poor choice due to its increased lubricity properties not allowing the rings to become seated properly. I've also read that this is a myth -- as many newer synthetic oils are designed to be used in the engine when it is fresh out of the crate. In fact, Mobil and Havoline make this claim on their web sites.
I even came across an engine break-in additive. This is the first time I've heard of such a thing.
The Perkins workshop manual does not specify a specific oil for the break in period. The engine was manufactured in the 1990's and has not been put into service yet. It has only had a few hours of bench test time recently.
By the way, the break-in period for this engine will be no different than when I use it as I normally would for cruising. I plan on running at a constant 2400-2600 RPM's, which is what is needed for the break in.
I'm inclined to use 30 weight non-detergent oil and switch to Amsoil after the break-in period. Any thoughts/suggestions/warnings? Thanks in advance...
