Hi folks...I'm new here, and glad to find this forum. So, I recently picked up a 1986 Bayliner Ciera 2755 in pretty good condition at a good price. It has the carbeurated 350 V8 Volvo Pentadrive. The interior, hull, and deck are all in excellent shape. It runs really well (I had it up to about 38 mph several times on the lake)...once I get it started. Getting it started seems to be the issue.
It started fine the first time out, but the next two times starting got difficult until it finally wouldn't start at all. Put it in the shop at a local marina, the mechanic replaced the ignition coil (the main problem according to him), plugs, points, etc. He tested the compression, and if I recall 4 cylinders showed 170 or so, 2 cylinders showed 150, and 2 cylinders showed about 100. He did some other stuff (fuel lines, fuel filter, fuel filler hose, shifter cable, pulled the outdrive off, lubricated it, changed the gear oil, and installed a new boot, etc.), plus trailer bearing and hub repairs. The total bill was about $1600. This fella seems to know what he's doing, and he has a good reputation.
He just finished this work, I went to take it out for the day, and guess what? It wouldn't start.
I finally got it started (the mechanic's apprentice was hanging out at the marina). This kid says that the automatic choke is causing it to flood because compression on 2 cylinders is low and it's not sucking enough fuel into the engine.
We did get it started by him holding the choke plate open while I started it. However, opening the engine bay and having one person start it while I hold the choke plate open everytime I'm starting it cold isn't an acceptable solution. What are you thoughts?
1) Is the low compression on 2 of the cylinders the likely cause of this starting problem? If so, will having the valve work done (assuming that's the issue causing the low compression) likely resolve the starting issue?
2) Would it be possible and feasible to disconnect the automatic choke, and just install a manual choke with a cable to the helm? Would that likely be a decent resolution to the starting problem? Or am I just covering up a symptom instead of actually fixing a problem.
3) Any other ideas? Seriously, any thoughts at all would be much appreciated.
I had one mechanic check this boat over supposedly good before I bought it, and paid him about $500 for that plus a couple of repairs (installing a new battery charger, oil change, etc.). I also burned up one of the trailer bearings on the 2nd tow, and had a guy come fix that and check all of the other wheels, service the surge brakes, and paid him about $600...apparently he didn't do such a good job at that because 3 of the trailer wheels were wobbly. I'm beginning to wonder if most of these mechanics are just true bone-heads.
Anyway, I really want to get this starting issue resolved so I can tow the boat to the coast for a few weekends over the remainder of the summer, so I'm looking for some good wisdom from you guys.
Thanks,
Thanks,
