gas guage bouncing-gctid385669
    I have a 2001 Maxum 3000 scr. And coming back from our cruise the starboard gas gauge started to bounce back and forth. Should I be taking off the gas gauge instrument panel to check for a loose connect first or could it be the sending unit instead?
    Roger:arr
    2001 Maxum 3000 SCR
    Twin 5.0L w/ Bravo 2
    Check for loose connections at both. start with easiest first
