How are you at trouble shooting Minn Kotas?-gctid385573
    I have a new Minn Kota Powerdrive V2 iPilot on a fishing boat. The trolling motor failed this morning. I ran it for a few hours this morning, on and off, and was returning to my dock. Chewed through some weeds, it slowed and then stalled. I picked it up, cleared the prop and dropped it into the water again thinking the weeds were too much. Now, the prop won't power up.
    I could use some trouble shooting help, before I pull it off and take it back for service.
    Here's what I know right now:
    The motor worked perfectly earlier this morning. I used it for traveling through the stump fields, holding position and a little maneuvering. Maybe 60 minutes total run time.
    The motor is less than 1 month old and has about 5-6h use on it.
    The batteries are less than 1 month old and have the same use on them.
    The batteries get charged every time I return home with the boat.
    I checked battery voltage as soon as I got back to the dock. In series the 2 batteries showed 25.05VDC. Individually they were 12.52VDC and 12.51VDC. This was immediately after using it for several hours.
    The Minn Kota's own battery monitor shows 3/4.
    The powerdrive steering still works, and will rotate the power head in either direction.
    When I press the PROP button on the remote to call for motor power, I can hear a relay click in the unit, and I get the beep tone to acknowledge the request for power.
    I cannot hear the motor in any way.
    The circuit breaker has not tripped (obviously - the steering and beep tones still work)
    The prop turns freely by hand.
    There's nothing visible in between the prop and the power head.
    The motor is hard-wired in, no plug between the unit and the battery.
    Any ideas, or must I lose it to warranty work for 6 weeks?
    Jam,
    Don't know a thing about them but a wild guess is their a sheerpin on the prop??
      This guy has the same issue. Perhaps an idea.
      What is the correct fuel line size for a 1988 Johnson, 90 HP ?
      A little more info.
      Minn Kota trolling motors have been around for more than 75 years. Minn Kota makes a complete line of small electric-powered motors that are used on fishing boats to move them around without the disturbance of a gasoline-powered motor. Although these motors are much simpler than their gasoline-powered counterparts, ...
        Success! I got it running again, but I'm not 100% certain what was wrong. It appears it was a software issue.
        I followed the troubleshooting advice here. Checked those sites Doug - same problem there.
        Shear pin was fine. No signs of moisture or overheating.There were no power supply issues and no mechanical things that I could see without stripping it down fully. I didn't want to get into that 'cause it's still under warranty. I completely powered it down, dissipated any residual charge, powered it up again and it was fine. Now I need to keep my fingers crossed as I give it a proper open water test.
        Thanks for all the advice, and stand by for a report after I test it.
