Have water in cabin area that is driving the admiral nuts. I have a 288 command bridge, when we return to boat after a week or so I find the carpet, behind the berth under the dinette, wet. The area specifically port side, near steps from entry, below the cabinet and dinette against hull. The storage cabinet behind the dinette is also wet. This is area where the seat back on the dinette opens up to gain access to storage area. And I mean wet, sometimes puddle in there, I believe the floor is wet due to seepage from above. I have cleared the window tracks and drains, several times. Sometimes debris builds up in there and clogs drains.
My boat is in rack marina, but outside of the building so subject to weather. I see a lot of discussion about bow rail mounting brackets leaking, but the rail is no where near this area, when I find water in the compartment I try to "follow it back" to a source, but I find the rest of the compartment is usually dry. Ususally the wetness starts about midway in the compartment, with puddle at back.(due to angle of boat in rack). Tell me where to look for this and how to trace. I have run hose over the area while at dock and find no active water intrusion in the compartment. Almost sure it cant be window because shelf below window is never wet or showing signs of water. Do I need to revove and reseal rub rail even though I can not reproduce leak while running water over that area? Stumped....
