So unless I get a firm date from the mechanic today, it looks like I have an engine to pull next weekend.
My 2003 285 will be up on sticks in the yard. I'm guessing the top of the engine will be about 4' above the ground, and the bottom of the arch will be about 14'. The transom is probably another 3' above the top of the engine, and so I'd have to clear that.
Looking at the usual auto supply outlets, I'm not seeing an engine hoist that can go from 4' to 14'. The specs are all in inches, between 70" and 88".
I guess I don't need to pull it all the way up to the arch and out. I really just need to get it far enough up to remove the oil pan. But the higher the better, as I'd like to be able to do some other jobs while it's up. Totally out of the way would be ideal.
Ideas?
Ideas?
