I'm working on my friends Mercury 7.4 l with Bravo 3 outdrive. It had the old pain in the aft drive leak at the swivel pin. We decided to fix it properly and not do the root canal method from the outside. To me that method of fixing a leak by creating more potential leaks does not make sense. I have the tools and technology so the drive is off and the engine is out. Since the engine is out and has been exposed to salt water in the bilge for over a year I am replacing any parts that show any corrosion. A new oil pan is next to impossible to find and priced at over $750. It has minor surface rust in spots and I will clean it up. I would like to know what is the best product to use to recoat it after the clean up?
Thanks for any and all ideas,
Dave M
Dave M
