My small lake boat trailer has one side of the axle that keeps making trouble, the seal surface is pitted and even with a good clean up with some fine grit sandpaper and bearing buddies it's still flinging out grease and drawing in water......I'll get to re-do yet another set of bearings before use again
In an attempt to avoid replacing the axle, I was looking at this:
http://www.jamestowndistributors.com...y+Spindle+Seal
But I don't really understand how it works. I thought it was a speedy sleeve type thing but it is different.
Anyone have any experience with these?
Just FYI this is a 1" axle, 1-1/4" seal surface, no brakes, under a 270# aluminum lake boat.
